Navigation Module
Anyone added Navigation to a 2013 or 2014 CX-9 by adding the navigation module located on the lower left side of the dash below the TSC switch? If anyone is planning on doing it maybe you could do a tutorial video and put it up on You Tube? I think it is a relatively easy job just a little expensive with the module running $4-500.00 .
Would be nice to find someone who's already done it though.
So you'll need the two parts, plus the SD card (if it doesn't come with). It does go behind the grey solid door at the lower left side of dash, the 'pocket assy' in step 4. Initially the salesman showed me the empty space and I could see the connections sitting in there ready to hook up. Looks easy. but I didn't do it myself and looking at the directions you're going to have to unplug the negative battery cable after taking down all of the system entries that will erase for re-entry later when you reconnect the battery. No idea how that re-inputting of the car data is done but it may be in the car manual or you might have to talk to a service guy.
Once the GPS was installed they left it to me to enter my home address in the system, and I sat there with the manual (the pdf link in comment above is the proper manual) programming it. They gave me the whole thing so I started at the Operation Check (5. in manual). Note that when it says 'press the power/volume' dial there is an outside ring on the dial and I think I had to press that, not just the inside button on the knob, when doing the #4 step with the SEEK UP button to get the AUDIO system screen. By following the directions the rest of the programming went smoothly for the GPS as per the instructions. If you happen to come out of the programming and not be able to get back to that Welcome! screen where it asks you to set your HOME address you can go back into the GPS and RESET to FACTORY SETTINGS and go through the procedure again. You can see in the directions on page 7 it also asks you to opt in to MAP SHARE and that is what the SD card is for. After I went through these settings I started using the GPS right away and it is a good one. It is a TomTom based system fyi. The only thing that I can't find is an easy way to get night colors on. I have found an area where you can choose color themes for the maps and there is a dark one (I think called Japan?), but it's not easy to flip to and doesn't do it automatically with a light sensor detector. My only disappointment with it; otherwise, it is detailed and works well.
It seems like an easy enough procedure as long as you're comfortable with the disconnecting of the car's electrical and bringing the system back up; I think that will be the biggest challenge.
I hope this helps. Good luck!
