Rough Idle 99 Silverado 5300
The idle on my 99 Silverado 5300 V8 vibrates the
seat slightly and the antenna sways about an inch
at top.
Took it back to dealer and they reprogramed but
still the same.
Tried another new 99 Silverado 5300 V8 and it was
slightly better.
This problem of idle smoothness seems rediculus as
my 94 Astro van idles smoother with a V6.
Many vehicles at idle are very smooth.
Anyone else with this problem and is there a fix ?
at top.
still the same.
slightly better.
Maybe you should try synthetic oil. Sometimes, rough idling can be caused by the EGR valve, or the PCV valve, either one. Or maybe a vacuum leak.
You put in your trucks VIN # and it will list program updates on your specific truck. I was not having any problem with ruff idle but when I put my trucks VIN in it listed an update. Last time I had the truck in for service I ask the service manager and he went ahead and updated the program. The truck was good before but now runs like silk. I don't understand all this programmable controller stuff but it works, they also updated the program for the transmission - like the idle it was good before but now it is the smoothest shifting automatic I have ever driven... I took the print out in with me
Hope this helps -
I tried response #5,s GM Program update index address of HTTP://calid.gm/vci/ and I keep getting
unable to locate server messages. Maybe the server is down. Anyway it would be interesting to try.
The dealer will do it for me if I leave the truck.
The dealers don't want to check basic things like
vacumn and spark plugs because if they don't find anything they claim they wouldn't get paid by GM.
Thanks again for your responses and post any news
on idle problem progress.
My expereience has been that it is best to find that tech that just graduated from school. They are usually well trained on the latest technologies and they are gung ho to get their hands on everything to gain experience.
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy1.cfm
I'd have it checked out.
I was wondering why it does this and something came to mind. Maybe for emissions reasons they run the mixture lean just until the idle degrades. This is easy to diagnose, I learned the trick looking over my mechanics shoulder. Shoot propane into the air intake and see if the idle smooths out. You need a small propane cylinder with a valve and hose attached. I'm going to try it and will post the outcome.
