Spark plugs
Can you tell me when do you know when your spark plugs needs to be replaced? (i have 167 000km and they have never been changed)
yes, even double platinum plugs. there is enough deterioration that under severe conditions (towing, 30 below F, making a sharp turn in reverse just above idle) there will be some loss of power noticeable to the driver.
course, I'm just cranky about being sure I get back from where I go....
If they are copper or platinum plugs like in an older model car, then yes, you should have changed them long ago, and I wish you the best of luck in changing them now.
for instance, on that ONE plug that simply won't come out no matter what... with a warm to the touch engine only, soak down the PLUG ONLY at its socket head with freeze spray, it might work wonders. don't try on an engine more than warm, you can crack it.
it did wonders on a seized up cast-aluminum Atwater Kent model H speaker assembly... blew off a couple ounces of freeze spray on the frozen adjustment ring (3" diameter) which had previously been soaked up in Liquid Wrench... took a CJ-12 Vise-Grip (tm), and it......... came......... off......... justlikethat. the guy who posted how to rebuild these 1925 speakers broke his all to hell and gone, had to do a lot of work with grey JB-weld.
