Tribute won't let the key come out of ignition.
chook2chook2 Member Posts: 2
edited April 2015 in Mazda
I have found that the P on the dash needs to have the box around it to let the key out but what is the best way to get behind the steering wheel to fix it. as I have not tackled airbabs before,?
Answers
  • larryb1963larryb1963 Member Posts: 26
    there is a by pass on the shift console look for a little square plastic cover 1x1in pry it open there is a leaver you can push to disengage the lock . most automatic car have them for this reason . as the lock solenoid goes bad . Google it for more detailed info . Shift park lock . sometimes you get lucky and its just a fuse . ck your owners manual .
