2015 Malibu LS bad ground clearance
knight006knight006 Member Posts: 1
edited May 2015 in Chevrolet
Does anybody own a 2015 Chevy Malibu LS. I have so much trouble with the airdam scraping
the ground on the slightest speed bump or driveway entrance. The LT and the LTZ have
no problems at all the all have better clearance due to bigger tires. I called Chevy and they
sentt me back to the dealer. The dealer does'nt want to do anything about it. If you buy a Malibu.
Do yourself a favor and go for the LTZ instead of the LS. The tires are too small and you will
be out of luck with the car scraping all the time.
  • secondchance22secondchance22 Member Posts: 1
    I have the same problem with my 15 ls talked to the dealer service and the only thing that can raise the front end is bigger tires and that sucks......
  • I have a 2014 Malibu LT it sits pretty low as well. I had to get the under shield re-attached because it was loose. Luckily the dealership did it for free.
