transmission not going in gear.
jlwhite1jlwhite1 Member Posts: 1
edited May 2015 in Dodge
Make sure you press on the break hard. There is a switch that the break peddle engages when depressed. This will allow you to shift out of park. If this does not work, I would replace the switch.
