08 Hyundai Tucson ABS module replacement
trish1773trish1773 Member Posts: 2
edited May 2015 in Hyundai
Does anyone know if it is possible to order a used ABS module and replace it yourself or have the local mechanic do it? There isn't much info on this on the net other than all four brakes need to be bled through the module and it needs to be reprogrammed by dealership after replacement. Please respond if you have any experience with diy ABS module replacement. Thanks in advance!
