Implausable left wheel ABS brakes, dash board lights go on and cruise control stops working U1417
I replaced the left wheel sensor however it is not the cause. The cause was an open circit in the wire going to the left wheel abs brake sensor. I had heard this to be the cause before but I should have checked the wire. Up in Ohio the brine that they use on the roads in the winter eats everything including the wiring harness. Trouble code U1417.
I ran new wires and spliced them at both ends and never had a problem after that.
