Swagger, Heft and the Roots of the Hellcat - 2007 Dodge Charger SRT8 Long-Term Road Test
Edmunds.com
The Edmunds long-term 2007 Dodge Charger SRT8 is nearly a decade older than a Charger Hellcat, but it delivers the same attitude.
But I'd like to hear more about the tired suspension and power steering, because at 110,000 km they should be anything but worn.
If you don't want to do a flush, try taking a turkey baster and sucking the reservoir out and refill with fresh ATF+4, drive a bit, then repeat until it appears bright reddish. Then just drain the reservoir and refill at each oil change or so and you'll increase the life of the steering gear and pump by quite a bit. The ATF+4 is a high quality synthetic fluid and any one that is licensed by Chrysler is essentially the same so pick up Wal-Mart's house SupeTech or whatever the cheapest bottles at the auto part store and you should be good (there's only a couple suppliers anyway that bottle and package for different resellers).
With the car's age and not knowing the service history a brake fluid flush ad bleed would help with ABS HCU life. If I bought one used of this era I'd also probably do a cooling system flush and replace with factory equivalent fill of Zerex G-05 coolant (same thing as Mopar but with different dye coloring) and distilled water if you don't know that it was changed recently and can't be sure if anyone topped it off with incompatible fluid (which degrades and cancels out the supposed "long-life" 5/100k change interval).
