2007 Liberty Harsh Shift or Tie-up When Cold...Help!
When I start the jeep, it jolts when driving it, but it seemed only until the engine would warm up, then it seemingly would run fine.
Everything I have tried is here:
The vehicle Harsh Shift or Tie-up When Cold
*DTC PO868 Line Pressure Low
*PO 934 Line Pressure Sensor Circuit Low
-Removed Pan Replace Filter
-Check SVolt Ref Circuit
-Check Line Pressure Signal Circuit
-Replace Transmission with used unit
-Replace Filter in Transmission
-Perform Transmission Relearn at Dealer
*Still have PO868 Line Pressure Low***
I am wondering if I need a new computer for the vehicle, if that is what the problem is, and how much one of those costs? Are they available used?
