Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
OR
ABS problem answered !
I have a 2009 Saturn Vue. ABS/stability traction error code.Dinging . Topped of the brake fluid and it corrected the issue. However, I will be replacing the brakes as this has much to do with the low brake fluid level. The sensor is to the right so when making hard left turns coupled with low brake fluid will cause the lights and dinging to occur. Thankfully, I am only out 80.00 for a diagnostic check which said I required a yaw sensor for 200.00. To only take a chance after the fact to put fluid in. I suggest you check your brake fluid before hand and replace your brakes before replacing costly sensors regularly and paying for a wrong diagnostic test. . As the Saturn's have the ABS problem reoccurring. I hope this helps:)
