1995 GMC 1500 steering pulling to right when braking
My husband has recently noticed that his truck pulls to the right when braking. He has replaced his brake pads for the first time (at 77,000 miles) and this problem was noticed afterwards. I am not sure if this coincides with the pulling or not. Does anyone know what may causing this? He doesn't seem to think it's a caliper problem since both brake pads were evenly worn. Any suggestions? Thanks
To get more difficult, when your husband pushed the caliper piston back into the caliper, he could have forced a chunk of dirt/rust in the brake fluid into an orifice, causing it to be plugged. This would prevent equal hydraulic pressures between the two front brakes. A steering component, such as a tie rod end, could be worn allowing the right tire to turn out slightly, giving the feeling of a pull.
There's not that many brake parts to give you trouble on your husbands truck. I'd start with the simple stuff and work your way toward the more difficult/expensive stuff.
Steering pull is a problem with the front brakes . Since it is only evident after the brake job, your hubby's work sounds suspect. The brakes may have worn evenly before, but now something is amiss and he's not getting equal braking force on both wheels. One side is braking more effectively than the other, causing the truck to pull to the side that's being braked harder. Is the truck just gradually pulling to one side, or is it diving across two lanes of traffic when you try to stop?
Basic question: he changed pads on both front wheels at same time? Hope so. Did he just change pads, or were rotors resurfaced too? Old pads and rotors wore together for 77K miles, they were matched set. If rotors weren't turned to make them flat and smooth, possibly one of the new pads is not making as a good a contact with the disk as the other side. This could give light to moderate pulling. Did he lube caliper pins when reassembling the brakes, one caliper could be momentarily sticking as brakes are applied. So braking force gets applied to one side sooner the other. Truck would jerk to one side, then straighten out as brake forces equalled. Did he need to bleed the brake lines? If so, did he bleed both sides - could be an air bubble on one side that's not allowing it to send hydraulic fluid to caliper - this would cause truck to severely pull. Another problem could be that he put a kink in one of the brake lines while the brakes & calipers were disassembled - this would cause uneven hydraulic pressure between the two sides. Check condition of metal brake lines and the rubber hydraulic line.
Harry
