Rear Brake light not working
Ok, so here is the long and short of it.
My 06 Chevy Equinox driver side break light is not functioning when the break pedal is applied. All fuses are fine, tried new bulbs, even tried switching the right side bulb (because that side of the break lights work fine), and no go. I've tried pushing the break switch under the steering column (Quick question there, should the motor be on while I do this or no? I did it while off.). The left break light (center light on left side of car), works just fine when in park, when the emergency flashers are on, when the turn signal switch is turned off of AUTO and pretty much any other time that the break is not applied directly. Thoughts? This issue has already gotten me pulled over once and ticketed...can't afford any more of those. Thanks in advance!
