Best Fuel Economy for 2015 Full-Size 4WD Trucks | Edmunds.com
Edmunds.com
Here are the fuel economy numbers for full-size trucks with four-wheel drive: the version that most truck buyers purchase.
Then to give the Ram an "A" because its diesel bested all other comers? Diesel fuel usually costs more and so does the engine option; why would you consider mileage your bottom line in the article, for rating purposes, instead of out-of-pocket costs? Nor does the article give specific tested stats we can go by to estimate how various options, such as axle ratios and the extra weight of longer vehicle lengths/configurations, might affect the EPA's and your test numbers.
On the other hand, one should consider the technology Ford is using and determine for his or herself whether that technology is going to work as a fuel saver based on his or her needs or wants in a truck. If you take a direct-injection, turbo-charged, gas engine; regardless of what the EPA estimate may or may not show; and laden it down with things that's going to cause this engine to take on extra load, be it weight or drag or gearing, then the technology used to help it beat out other trucks in mpg is going to be diminished. And that's what is showing through with Edmunds truck and the 2.7.
I've got the lightest and smallest and highest-geared version of the 2015 F150, and the 2.7 liter Ecoboost, and unlike their woeful results Edmunds is finding with a steroided version of this truck (which is admittedly what most people buy), I'm getting just a little more than the combined rating of 22, sitting right now at 23.6, driving conservatively. But keep in mind, my truck weighs in at less than 4200 lbs; has 3.31 gearing; is 2wd; and is a short bed at only 122" wheel base.
The point I'm making is that Ford's strategy has the power and torque to make it very acceptable in all configurations and driving styles from a performance standpoint, however, for this truck to excel at mpg, it has to be babied and it helps if its a baby version of the truck.
