Park assist sensor won't start.
podom2007podom2007 Member Posts: 1
edited October 2015 in Chrysler
Ok so background info:
OBDii connector does not function first and foremost.
Battery has been tested and its fine.
Starter has been tested and its fine.
Both fuse boxes have been checked and they are fine.
Since OBDii doesnt work did the key trick to show trouble codes on dash and nothing showed.
HOWEVER, the dash continuously says that the parking assist sensors need to be serviced, but from what ive read this shouldn't impact the car from starting.
So I parked my car in the garage one night and next morning went to leave and started the car right up as usual but when i put it into reverse and started to back out It died. This happened about 3-4 times and then it stopped turning over completely. I'm lost as to what the issue could be. Any advice or input would be greatly appreciated.
