95 Dakota Stalling
porter13porter13 Member Posts: 1
edited October 2015 in Dodge
My 1995 Dakota will stall while I am driving and will not start if I take the battery cable off and put to back on it will start but will do it again have replaced the fuel pump, fuel pressure regular, fuel injectors, Plugs, plug wires, rotor, distributor cap, coil, crank shaft sensor, egr valve, all three Sensors on the throttle body, and cleaned the throttle body, the pmc, and cam sensor. Does not give any codes.
