Dodge Neon using a lot of oil (no outward signs)
My friend has a 97 Neon with 101,600 miles. She drives 400-600 mi. a week and is using 1 or 2 qts. of oil weekly. No oil drips on ground; no smoke is visible from exhaust; valves don't knock. She has oil changed every 3,000 mi. Does anyone have an idea what can be going on? Car is running good now, but could she be facing a breakdown? She must have a car for work. Should she look for a new car? Thanks for any help you can give!
A headgasket job on a Neon is a 2-2.5 hour job with about $80 in parts. Don't let anyone soak you, if that's the deal.
Seems like it would take a lot longer.
And, I don't know why a blown head gasket would allow the engine to still run good but use oil without it being visible.
I'm thinking it might be valve guides. Still, it should smoke. that's a lot of oil consumption!
DaimlerChrysler pays 2.1-2.3 hours, depending on whether the car has a/c and what transmission is involved (more emissions hose routing to deal with on automatic cars), Chilton's pays 3.0-3.2.
We had Neons come in all the time running fine, with 2-3 busted connections in the head gaskets...
-B
1. burned
2. leaked out
Also, there really should't be a correlation between head gasket and oil consumption unless the oil is leaking to the outside of the head gasket and dripping down the engine.
An internal leak between an oil galley and a combustion chamber, such as a cracked head, would cause a severe degradation in performance, that you would notice immediately. The car would hardly be driveable.
I suspect you have internal engine wear, either rings or valve guides.
Best way to test is have someone follow behind you while you:
1. Climb a hill
2. Coast down the other side of the hill in a low (engine braking) gear, like 2nd, without using the gas at all.
3. After coasting for15-30 seconds, hit the gas and note the color of the exhaust. A big puff of blue smoke (which your following car might see a lot easier than you) tells you the story.
