Visitor Agreement.
Answers
1. Remove the 2 bolts holding the pressure hose on top of the power steering pump.
2. Jack up car and place a large drain pan underneath near the steering rack.
3. Disconnect the electrical connector to power steering pressure switch (blue arrow is power steering pressure switch, which is attached to pressure hose at the other blue arrow). You will re-use the pressure switch, so get a new o-ring; but, remove the switch after you removed the hose.
4. You may have to remove the brackets (red arrows) holding the rubber bushings attached to the hose.
5. Then disconnect the pressure hose fitting connected to the steering rack.
