Runs fine, revs fine. Put in gear and it dies.
memturbomemturbo Member Posts: 1
edited January 2016 in Chevrolet
I have a 94 chevy van with the 5.7l tbi
it has new , IAC,Distributor,fuel pump,fuel filter,wires,plugs,diz-cap ,rotor , fresh gas
It will start up and run all day no codes or lights when you put it in gear it will die
I can feather the gas and it will continue to run down the road and it shifts fine as long as i constantly feather the gas
if I try to just floor it it will die .
At stop lights it will only run in gear if I keep feathering the gas.
I checked for vacuum leaks and checked the tbi gasket for leaks .
