Visitor Agreement.
Get an under the rail with some kind of seperate rail caps...metal or plastic.
That way the caps won't move around as much...or at all!
Spray-ins are a great idea...but they are not quite there for protection yet.
Rhino is way too rubbery...and Line X...while being the better choice....still won't handle the abuse of a shovel or hard blows like a drop in will.
I have yet to hear anyone tell me an actual work story of a spray in getting used hard. Just stories of how they Look pretty...(I'm sure this is going to flare some people up!)
Good Luck
- Tim
I've had all three. The drop in style expand and contract with temperature changes. They also bounce around. The over the rail type mess up the paint on the top of the rail and in the bed. The under the rail only mess up the paint in the bed. USUALLY (20 people will call me a liar but...) the paint only takes a beating where the edges of the liner rub the paint. In SOUTHERN CALIFORNIA, the drop in liner move enough to keep rust from forming where the paint has rusted away. I can not speak for harsh winter areas of the country. I'm close to the "Salt Air" and neither truck rusted where the bed liner rubbed the paint off.
This time I went with the Line-X spray in. If you work at it, the liner will chip. I had to bounce a 100# lawn mower over the gap between tail gate and bed to chip mine. (Just after getting it sharpened.)
I prefer the spray in to the drop in type in all areas except friction. There is too much friction between the liner and load for my taste. Now when I toss a box in the bed, I can't slide it to the front of the bed without climbing in to the bed. A minor irritation.
If I had to do it over again, I would still go with the spray in.
Rich
Good ones like a Duraliner...or a GM Liner (made by Duraliner)...don't change at all as far as the eye can tell.
it's all up to each his own i guess.
I've almost had myself convinced to go with both type of spray ins for the new truck....but still ended up with a Duraliner.
..Good old reliable I guess?
Can't teach an old dog.....
- Tim
The new one I just got is one nice piece of work Rich.
Off brands don't put enough time into them to make them fit the bed good. You end up losing space also.
Spray ins are a great idea....but more for the person who wants it for looks and light work.
I'm not a construction worker...but do abuse it often with shovels and large rocks from time to time.
Spray ins are more of a disco type....Drop ins are the true work hogs.
Good choice Shawn.
- Tim
..Kinda like Kleenix and ordinary facial tissues..
The new duraliner I got is like an exact match of the metal bed...that fits perfectly.
Some off brands "angle" in from the inside/top bed rail towards the center of the bed...creating a narrower bed. Some just go straight from the bed rail inside...down to the floor...and sacrifice width.
I have strong feelings about some things....and this is one of them.
I'm sure off brands may hold up as well....I know...I have had one....but it sure didn't fit like a Duraliner...(or GM liner..same thing)
Yeah...it's $300 instead of $125...and they probably make more on the $125 than they do the $300....but I have always felt..you get what you pay for.
I don't mean to preach...Just trying to help.
Another thing....some under the rails are screwed to the sides to keep it in....The Duraliner is made to fit so exact...it has some "high" spots that "snap" into the bed under the rails ..so to speak. No screws..(except for the tailgate piece)
..Does that make sense?
If you like..I can take some pics and you can see the fit quality for yourself.
Good luck
- Tim
Unfortunately it sucks. It is bowed up in the center rear and won't sit flat. I kept a 6x6 on it for a month and that didn't do it. I glued it down with silicon glue and it pulled loose due to movement with temperature. This thing grows and shrinks by easily 1/4 inch in length just from moderate nights to sunny days. Makes me so sick I'll probably end up with a Line-X.
(For drop ins..)
- Tim
I like the spray on liner - If it gives me any problem I will just put a drop in over it.. A cheap drop in is only $99 and I do not think the extra 1/4 inch of space the spray on takes up would cause any clearance problems.
Has any one tried this?
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
