Grinding in front end
runner4itrunner4it Member Posts: 2
edited February 2016 in Toyota
Here is the problem. Was having fun in snow in 4WD hi on the dial setting. Doung donuts in parking lot. Heard a loud pop and then the vehicle would not go either forwards or in reverse. Turned dial to 2WD let it disengage from 4WD. Once in 2WD I was able to drive normally. After a while I tried to engage the 4WD again, placed in neutral turned dial to 4WD hi and then shifted to drive. Heard grinding coming from front end and vehicle still would not go forward or in reverse. Help
Answers
    Sounds like your going for some $$$$. Should of just went to Dunking donuts called it a night :smile:
