Timing belt housing gasket
solemeanssolemeans Member Posts: 1
edited May 2016 in Isuzu
Putting water pump on my 3.2L v-6. Changing timing belt, hydraulic tensioner, & idler pulleys as well. When I pulled the 3 covers, the foam gaskets were bad. Looks like they only act as seals to prevent dirt from getting into the belt & gears. Can't find them anywhere. What's the solution?
