Throttle Actuator Control Module Processor
zibik27zibik27 Member Posts: 1
edited June 2016 in Ford
I am continuously getting p2110 and p2107.
When vehicle is cold or outside temperature is colder than 80 degree, I don't have any issue.
However, when it gets warmer my Expedition is loosing the power and engine works rough.
I still can continue driving but there is almost no acceleration and maximum I can drive is 50mph.
The throttle body with sensor were replaced and works good; similarly the air sensor was replaced and works good. All cables and hoses looks ok. What else should I check?
  • alwaysfords2alwaysfords2 Member Posts: 339
    Not really in my area of things I understand, but in another forum someone reported having the PCM reflashed at the dealer cleared this up after changing parts didn't work.
