1999 ZR2 Tranmission Issues
eubanksjaeubanksja Member Posts: 1
edited August 2016 in Ford
have a used 1999 ZR2 with a transmission issue (71K). I have a used "tested" replacement transmission but before I replaced I wanted to see if there were any other things I should check first. The engine runs great and the transmission smoothly shifts from drive to reverse. Issue is that it will not move out of low (max speed ~25 mph).
