Impala tranny or shifter
Good morning I recently tried to put my 2001 Chevy Impala 3.8 column shift into gear and the shifter broke off completely from the column. I replaced the shifter and the cable to the ignition as well as the cable to the transmission through the firewall what I discovered was the little arm that the cable connects to is seized up. Also my ignition stays on even with the key out it does not go all the way to the off position anymore what have I done and can this arm be unseized somehow without rebuilding the transmission? Any facts and feedback would be appreciated
