Ford Edge SEL
mcsoucymcsoucy Member Posts: 1
edited November 2016 in Ford
I own a 2007 Ford Edge SEL. I have no heat on the drivers side. I replaced the thermostat, flushed the heater core, and replaced the Blend Door Acuator and the heat on drivers side is still not working. Has anyone had this problem? How do I fix this problem?
  • tank101tank101 Member Posts: 1
    I have the same problem with our 07 Edge. Have you found any results as to fixing the problem? I've tried everything as you did. Thanks
