Monthly Update for December 2016 - 2016 Chevrolet Volt
Edmunds' 2016 Chevrolet Volt spends December making some engine-heavy hauls and taking its first venture into snow.
Diligence? Not straightforward? The onboard computer in the Volt's infotainment system makes it easy. The Energy > Info screen shows the "Energy Usage: Since Last Full Charge" split between electric miles/kWh and gas miles/gallons. Simply record the data before plugging in and keep a running total. The running total of gallons you record from the computer is very close to what you ultimately pump at the gas station. I'm not talking about the bogus MPGe, just the MPG when the gas engine is running.
The city MPG is blah, I agree. If I know from a full charge I'll be driving more miles than the typical battery range of 45-60 miles, including a bunch of freeway miles, I use the "Hold" mode to force the gas engine to run on the high-speed freeway when it is most efficient (44 mpg highway vs. 36 mpg city), then I switch to the "Normal" mode on the slower city streets where the electric motors are most efficient.
