Silverado Tire Wear
I own a Silverado LT, extended, 5.3, 3.42, and the
tires are wearing (feather edges.) I have had the
alignment done twice, rotated them @ 7000mi and
again @ 12500mi. The Dealer said this is normal
"Alignment within factory specs.", "normal
charactoristics for these vehicle to wear the
outside edge, recommend tire rotation every 4-6k
miles." He went on to say that this condition is
also normal with Doges and Ford trucks! Any one
have any ideas?
have any ideas?
made lighter on gmc and chevy. so the suspension is now changed and causing various problems.one story i heard was when the rear end was jacked up on a silverado the frame bent almost against th e cab. i was told that the suspension could not be
up graded because of th e lite frame. i'm trying to get more info of this but have not have much luck.
You might want to have the balance checked. If the factory just static balances (don't know that they do or don't), you may want to invest in a dynamic balance. I doubt this would cause the wear, but it could affect the rate of wear.
If caster and camber are correct within spec; is the dealer checking the toe angle? If wear is on the outside, the wheel may toed in too far. If wear is on the inside, the wheel may be toed out too far.
Also, if you have a 4x4 with the pushbutton 4x4 option, keeping this in autotrac will lock the hubs all the time. This might have some minimal effect on tire rolling when turning.
Just a few thoughts.
Like said..check pressure often...as the cold hits...you will be amazed how much the pressure can change. My rears went from 80 to 65 with just the change in temperature one time.
I have the on/off road type...and just rotated for the first time at 10,200 miles...the fronts had more outside wear..but no bad patterns..and the rears were flat as glass. they also ride just fine being on the opposite ends now.
- Tim
But what I noticed, was the especially minimal wear on the brake pads, all 4 wheels. Looks like they could go 45-50 thousand miles at this rate.
I'm easy on it.
I'm not saying I won't try some other tire, but I don't think anyone knows what's better. Pretty sure I don't want the Michelin or Goodyear. Maybe the Bridgestone Dueler A/T with Uni-T, if I had to choose today.
I hope to be able to give a report on the Bridgestones in about 6 months. Hope to take delivery of my new Z71 by the second weekend in April, it is going straight in for the Bridgestone Dueler AT - 285's. The Firestone store where I've checked prices definitely pushed that tire over the Firestone, and I like it better than the BF Goodrich, which seems to be the most popular tire out there. After seeing Goodyear on the web I didn't like their tire, so I'm not shopping any further.
What has sold me on the tire - the Uni-T construction, half aggressive tread (the truck may never even be off the road), claim of still a smooth quiet ride, Warranty of free replacement - 50,000 miles, and 30 days no questions asked return if I don't like em at all.
I'll let you know in several months.
Greg
What happened to him man?
- Tim
rcoos
His chief mechanic, Ray Evernham quit to run the Dodge Intrepid next year. The rest of his rainbow warriors mutiny'd over to the Robert Yates team of Dale Jarret and Ricky Rudd.
found out on the inside that they messed up the suspention and i'm seeing a
lawyer. I've put on shocks, springs, tires, get rid of it. remember this is a 2WD ONLY PROBLEM,LARRY P.S. DON'T PUT ANY MONEY INTO THE SUSPENTION, NOTHING WORKS
it is unwieldy to manage, and difficult to use for "newbies". There is entirely TOO much topic duplication, so I will be doing some SERIOUS topic consolidation in the next few weeks, getting us down to not more than 2-3 topics per vehicle type, and ultimately down to 200 topics or less.
THIS weeks consolidation candidates are: F-150's, Silverado's, Dakota's, and Dakota Crew/Quad cabs.
In that vein, please consolidate this Silverado topic to Chevy Silverado - Continued IX and continue these discussions there.
Front Porch Philosopher
