I have a 2001 dodge dakota 4.7 and when i put it in reverse it hesitates to reverse why?
andrewg22andrewg22 Member Posts: 1
edited April 2018 in Dodge
I have a 2001 dodge dakota 4.7 4x4 and when i put it in reverse it hesitates and i dont know why.
Answers
  • inuvikinuvik Member Posts: 163
    It could be a number of reasons such as low on ATF, restricted flow due to partially plugged filter, ATF degradation due to irregular or non-existent maintenance, solenoid malfunction. Check your fluid level according to the owner's manual. If it's ok, then change the filter and fluid. Most of the time this will alleviate the problem.
