2009 Mercury Mariner P0302 Cylinder #2 Misfire---NEED HELP!
2009 Mercury Mariner, 2.5L 4cy, fw drive, 180K miles, replaced tranny 2 years ago with a used one that now has about 90K miles on it. I have been getting a P0302 error, signifying a misfire in cylinder #2. When I put the vehicle in drive, with the break down, it slightly vibrates, but when I pick up speed at around 45-60mph, it vibrates at a much more intensive rate. I have replaced all of the plugs, changed out the coil packs, and replaced the valve cover gasket. Still no change in the vibration. Did compression tests on all 4 cylinders, and they all came back at 120. I have been told that it could possibly be the torque converter, but are there ANY other items that could be causing the P0302 error? I don't want to get into changing out the TC, if there are other items I can check first; or, is there a way to determine exactly if it is the TC? Any help is greatly appreciated!!!
Answers
I'm no expert, but I'm curious how the torque converter would have anything to do with a misfire. You certainly could get a vibration from a TC problem, but connecting that to a code for a misfire seems odd.
