Is there a way to block/disconnect/isolate the hybrid system and just run it as a gas vehicle?
I have a 2007 hybrid that continuously stops running. I see lots of threads and discussions by people with the same problem but with no fix. I get the pull over safely and stop message as the car shuts down but no other codes.
Is there a way to block the hybrid system and just operate on the gas engine?
Best Answers
PF_Flyer
Member Posts: 9,372
I don't that there is or isn't, but my gut is telling me this would not solve the issue since the system is designed to work together.
I also googled to see what I could find and saw lots of vague information as well. Corroded resistors, testing of power connections and grounds. Perhaps one of the techs that hang around here will have a better idea of where to start5 -
thecardoc3
Member Posts: 5,871
There should be some codes setting and pertinent data related to the system shutting down. Has an experienced technician gotten to take a look at this?
5
