RV towing
audioengaudioeng Member Posts: 1
I have bought a Jayco Eagle 26' fifth wheel travel
trailer and am shopping for a pickup to pull it.
I want a truck that will be adequate for pulling in
mountain areas. My preference is the Ford F-150
Supercab with the 5.4L engine. I have been told
that this will pull the camper fine but would like
comments from those who have used it. Thanks!
  • stevekstevek Member Posts: 362
    http://www.rvusa.com/index.html
    check this site out for RV related stuff, good bulleting board
  • wight1wight1 Member Posts: 218
    I would absolutely recommend you go to a 3/4 ton truck for your trailer. I'm pulling a 26' Mobile Scout travel trailer with my Silverado 3/4 ton and am very happy with this setup. Before buying this combination, I did a lot of soul searching about the decision between the 1/2 and 3/4 ton truck, and now I'm really glad I went with the 3/4 ton. I can't imagine pulling it with a 1/2 ton truck.
    In my opinion, you have a number of things working against you if you choose a 1/2 ton. First is the high hitch pin weight of a fifth wheel trailer, which is going to put a lot of strain on the frame, axle and tires. You will probably have to add a set of helper springs or airbags on the 1/2 ton truck for level, stable towing. Also, despite what the sales brochures and salesman will tell you about the 1/2 ton being adequate for a fifth wheel trailer, they really are not because of the higher loads imposed on the rear axle gears (see the RV Clinic section of this month's issue of Trailer Life magazine for a discussion on this subject).
    Secondly, if you're towing anything heavier than the weight of the truck itself, you want to be sure you've got adequate braking power, especially in an emergency situation. Even with the trailer brakes, I don't think a 1/2 ton is anywhere near as good as the brakes on a 3/4 ton, regardless of which of the Big 3 you choose.
    And most important, you say you want something adequate for towing in mountainous areas. Considering all of the above loading factors and braking issue, you're going to be a lot better off with a stouter vehicle under you in the mountains.
    I would recommend you go with a 3/4 ton vehicle.
  • tundradudetundradude Member Posts: 588
    Get a F250!!!
  • mictromictro Member Posts: 29
    Ditto! Get a 3/4 ton!!!
  • markbuckmarkbuck Member Posts: 1,021
    Towing my 5,000lb trailer with a 1/2 ton Silverado with 4.8L motor. PLENTY of motor, and brakes are great. Have to use a equalizer hitch, expecially when the bed of the pickup is loaded with toys.
    NOT happy with towing performance from the standpoint of spring rates, wheelbase, and general mountain towing stability.
    I have a 2001 Chevy HD 3/4 ton on order. If I were you, would go with one of the SD since you are a ford man.
  • rs_pettyrs_petty Member Posts: 423
    The question to answer is not which truck will tow the trailer, but which truck will not be driven by the trailer. You don't want the trailer pushing the truck around. I'm with the others. Go for the 3/4t, but if you think you are going to get crosswinds in the mountains I'd consider a dually. Maybe overkill, maybe not as your staring off that 5000 ft drop.
  • tmigueltmiguel Member Posts: 33
    I have a 2001 2500 Ram with 5 spd V-10 4x4. I did a lot of homework and I wound up with agreat rig to go up and down hills using manual gearing.
    With Dodge, there is a BIG difference bewteen the 1/2 and 3/4 ton pickups. Get a 3/4, if you worry about slowing down a trailer down a steep hill, get a stick shift gas engine, like a V-10 that has lots of torque to slow down your rig without brakes.
  • mgdvhmanmgdvhman Member Posts: 4,157
    This is a no brainer...go with bigger brakes..frame..axles...engine..better tranny gearing...aka - 2500!
    Yeah the 1/2 can do it....for a short trip...but long ones...no thanks. Plus when empty...you will have a better riding..better braking truck.
    It's like Electricity....a 20 amp circuit will pop at 20 amps....but for a continuous flow...go about 80 percent of that...or 16 amps.....take the max trailer Load...about 11K for a gas 2500....and take 80 percent of that for a long trip....anything above....get a diesel.
    2500's are geared better in the tranny also for this job. My 00 2500 Silverado seems sluggish sometimes when empty with a 2.48 first gear instead of 3:06 like a 1/2 ton....but when loaded down...it's oh so nice to have the engine get up into the torque band much quicker...
    get a 3/4.....regardless of brand you select
    Good luck
    - Tim
    When empty, the 1/2 ton has it all over the 3/4 ton. I get to drive both regularly.
    Tim, I don't buy your explanation on either the electricity analogy nor the 1st gear - torque band thing whatever that is.
    That's where personal preference comes in. I like the ride and better feel of the road of an empty 3/4 better than a half. I feekl it's the superior choice for me.
    Ask any good electrician....they will tell you for a constant load...aka a few hours...you should go 80% of the breaker. They pop by two things...heat and power.
    The same theory for towing large loads would not be that farr off from that theory....don't buy it?
    Then don't!
    I have others buyers.
    - Tim
    what's that word!?
    make that FEEL
  • quadrunner500quadrunner500 Member Posts: 2,721
    Chevy Silverado...THE TRUCK
    Strike the chord Bob Seger
  • RoclesRocles Member Posts: 982
    Ugh...Didn't he die yet? (Kind of like the TRUCK?)
    Anyway, a 3/4 tonner is best with such a long and heavy trailer. If you use it once a year-then get a heavy half but frequent use requires a beefier truck. Duelly isn't needed--Hell, Ford and Chevy offer one-tons in single rears.
  • z71billz71bill Member Posts: 1,986
    Lets not rush into this 3/4 ton truck decision-The trailer is 26 feet - but the real question is how much does it weigh and also what is the weight of the hitch pin (weight that will be in the bed of the truck). I looked at buying a trailer and was surprised by how light some of the new models are when compared to trailers made 10 years ago. After you know the weight of your trailer then you need to add the weight of all the gear, food, propane, water & toys you will also be hauling --- Then you need to get the 3/4 ton truck.
  • rayfoxrayfox Member Posts: 1
    The issue is really what does it weigh as someone else indicated. Assuming >5,000 lbs. the F-250 is the way to go.
    I carried a 25', 4,800 lb rig on my F-150 5.4L SC, 3.73 rear for the last year. Went up and down hills all over Arizona, Utah and New Mexico during last years vacation. No particular problems but clearly this rig had little reserve power or weight carring capability.
    Get the F-250. Regards.
  • tracyotracyo Member Posts: 72
    I just got back from taking the family on first camping trip, first tow, with my 00,f250,xlt,psd,
    6spd,3.73,. I pull a 27' t/t wieght: 6700-7000lbs
    plus family of 5 and supplies. This truck is awsome! I traveled the interstates-65,20,75 down to Orlando, Fl. 1400mi round trip, I would set the cruise on 70mph in 6th gear with air on entire time, no hill-grade even gave a hint of slowing my truck that turbo would just sing a little. I averaged 14mpg at this speed. I never even put my sway control on, just drive along one hand on the wheel and relax. I have been pulling this same load with my 95 f150,xlt,302,auto,
    and that was a hand full. I am so pleased with this truck.
  • wildmanbakerwildmanbaker Member Posts: 65
    We had a 1/2 ton 95 dodge and a 26' terry. It pulled and stopped OK. We traded for a 99 3/4 diesel. Although the 1500 towed alright, it was a beating on long hauls. With the 2500, it is a breeze! Allot more stable package all around. There probably will not be much difference mileage wise between a 1/2 and 3/4 ton pickup. Tim's right, the 3/4 rides better empty too.
    Wildmanbaker
    ..someone AGREES with me yet again?
    I will say it's a harder ride over bumps...but at highway speeds and smooth city...it's so much more solid and in control...for me.
    Even the bump times are not bad...they are faster smaller feeling bumps....if that makes sense?
    ..for me.
    You have to try it out yourself.
    - Tim
    Tim, lest you get carried away, Wildman is comparing Dodges. Association comes with risk...
    I'd have to say Dodge is as risky as it gets!
    LOL
    - Tim
  • meredithmeredith Member Posts: 575
    After 30 or more days of inactivity....
    this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
    Front Porch Philosopher
