GPS issue
R_10R_10 Member Posts: 2
edited December 2018 in Acura
I purchased the software update for my Acura MDX GPS last year, had the dealer load it and it thinks I am in California instead of Georgia, can't find streets or addresses I know were there before I loaded the update. Has anyone else had this issue or have suggestions on how to correct it?
    Looking at the Nav manual:
    http://techinfo.honda.com/rjanisis/pubs/OM/TX1010/TX1010NV.PDF
    Looks like you have to edit the Home 1 address. The System Setup section of the manual starts on page 94. Once you open the document, you can also hit CTRL+F and type in "home 1" so you can quickly move through the manual and find the info you need.
    Hope this helps!
  • R_10R_10 Member Posts: 2
    the home address is the same as it was before the upgrade,
  • rickdonrickdon Member Posts: 123
    I would go to the dealer and tell them the issue.
