2001 TUNDRA
looking4infolooking4info Member Posts: 1
edited March 2014 in Toyota
Does anyone have any info on the 2001 Tundra,
major improvements, if any? New styling? Release
Date (probable)? thanks.
  • trucksrmetrucksrme Member Posts: 381
    They be the same. That factory is workin on them Sequoria ones now, that be the focus for sure. Good luck on this one now!
  • devil1devil1 Member Posts: 74
    I've heard they may come out with some new colors. There will absolutely be no styling. When a company makes a new truck, it's usually at least 3 years before they give it a facelift, then 5-6 years before a major redesign.
    The only thing they need is more color options (preferrably a flat red), and the backseat at a 15+% angle.
    (Trucksrme will help me out with all the other things it needs, right?)
  • z71billz71bill Member Posts: 1,986
    I think it would be hard to give the Tundra a 15 degree angle to the back seat - it would eliminate to much leg room, or make the rear seat so narrow you would need to sit side saddle with only one cheek on the seat.
    Wonder what year them tundras goin be "full size" now? Good luck on this one now!
    See Rear leg room is not what the problem is with the Tundra at least to me (It's not a plus either). I test drove F-150 and Tundra, and the F-150 seemed quite a bit bigger back there, but it really wasn't when I think about it. Then I go over to the Tundra and it seemed smaller only because it was by an inch or two in back, but mainly because it is so upright. I would rather have the seat at a slight angle and loose a couple of inches of legroom.
    Needless to say I don't care too much because my wife has a CR-V and it fits 5 people fine, I have no friends ever since my baby was born, and the only person I have to haul in the back is my baby. So any truck would work for me.
    IF I HAD to take 4 ADULTS with me everyday (How many people do???), then I would go for the Ford for sure.
    I am not considering the Silverado or Ram. I don't like the styling of either, and reliability is a major issue with both.
    This be a fine one now.
  • quadrunner500quadrunner500 Member Posts: 2,721
    Isn't that the Tacoma quad cab?
  • ford250ford250 Member Posts: 25
    HEY DEVIL1 WERE DID YOU GET THIS PICTURE OF A FOUR DOOR TUNDRA. I WOULD LIKE TO GET SOME MORE INFO ON THIS NEW TUNDRA, SO CAN YOU PLEASE TELL ME WERE YOU FOUND THE INFO THANKS.
  • lukacslukacs Member Posts: 23
    ...at that picture. As you can see, the rear side window is split in half and it curves up on the bottom before the split. Also, part of the door handle is still visible on the front part of the rear door. So whoever made that picture needs some more practice with that Adobe Photoshop (or whatever he/she used)
    I found the picture on:
    www.soar.to/trucks
  • dbhulldbhull Member Posts: 150
    That is not a Tundra. Just like what was already mentioned....this is the new Quad Cab Tacoma due out next year.
    Nice try.
    That owners of the Tundra have a hard time telling the difference between their truck and the compact Tacoma.
    ... it is a Tundra, but as I mentioned before, that picture is a fake. Look at it.
    THAT PICTURE WAS A TUNDRA LIKE AT THE WHELLS & TELL LIGHTS THEY ARE FROM A TUNDRA.
    Hard too tell them tacoma and tundras apart now, they be sharin so many parts, and be about the same size now. Good luck on this one now!
  • lmeyer1lmeyer1 Member Posts: 215
    As noted, it's not the Tacoma Double Cab. Doesn't really look at all like it if you put them up side by side on the screen.
    It's a fake, and not a very good one. Look at the vertical line in the rear window, just where the Access cab would end.
    No offense intended here, but....if this is a Tundra, it kinda shows how small a Tundra is. I would swear that was a Tacoma, especially looking at the front end. They have the same swoop. I thought a Tundra had a bigger, wider front end.
    It sure looks like a compact truck from the picture.
    Them tundras are compact trucks now. They sure aint "full size", as any folk can tell by that picture. Good luck on this one now!
  • tundrasaursrextundrasaursrex Member Posts: 49
    You drive a '52 chevy and whine about the size of the Tundra?
    Go figure...........
    That 52 be used on the farm, it really belongs too rubluetoo I reckin. Franklin got him a 2000 Silverado LB, he lends it too now and again. I be lookin too buy me a new 35000 Silverado later this year, that ones got the haul I be needin now. Good luck on this one now!
  • rushfan2112rushfan2112 Member Posts: 27
    Thirty-Five-Thousand? By golly that must be a REAL BIG OL' TRUCK!
    That be that 3500 one now. If they made that 35000 I be goin for it though. Good luck on this one now!
  • meredithmeredith Member Posts: 575
    After 30 or more days of inactivity....
    this topic is being "frozen." it will be archived or deleted in the next 10 days or so.
    Front Porch Philosopher
