I need help with engine replacement
I have a 99 Suburban and need to replace the engine. I have found an LT1 350 92 model. Will it work in my Suburban?
____________________________________________________________
Why the concern? If this engine has not been abused it should be good for at least 150K miles.
This sub had 1 owner, that I can't get in touch with (got name off of carfax). It appeared that he towed, due to some bumper scratches and the AR extra. They said that it makes a difference. Is there anything else I should check before final purchase. Transmission seemed ok. Runs great.
Towing should not be an issue if the vehicle has the towing package...unless it was used in a commercial towing/heavy hauling operation or something like that. Your best bet would be to have the vehicle inspected by a professional. Might cost $150 or so....but it could save you big money in the long run. Have them check the engine, transmission, rear end, and 4 wheel drive components. That is where the big money repairs are. You will also want them to check out the brake system,AC/ electrical, etc.
