Dodge Sprinter Heat/Air Conditioning Questions
dburlisondburlison Member Posts: 1
edited October 2014 in Dodge
I have the small wheel-base Sprinter Van. I would like to install a Roof-top Air Conditioner, however, I'm not having any luck finding information about MB factory or aftermarket units. I would really like the lowest profile unit available on the market. Any suggestions would be greatly appreciated. Thanks.
  • sprinterdocsprinterdoc Member Posts: 11
    I don't know if you can install MB unit on the roof, but price for evaporator unit only (roof unit) is approx. 3000.00 dollars. :)
  • jim314jim314 Member Posts: 491
    I have wondered about the MB factory roof top a/c unit. Is this just the evaporator unit and it is fed by freon from a compressor in the engine compartment, or is this the entire unit with an electrically powered condensing unit?
  • kenbakerkenbaker Member Posts: 239
    Factory roof unit is fed from a (second) compressor under the hood, and is the CONDENSOR, with its own 12v electrically driven fan to draw air across the coils (compressed refrigerant fluid (gas or mixed phase gas/liquid) is cooled to make liquid to go to the evaporator for expansion/cooling cycle). This is why you need the heavy duty alternator when you have roof air on the Sprinter.
    The interior rear unit is the evaporator, and provides rear cabin air circulation, dehumidification, and cooling as the liquid refrigerant expands into gas across an orifice and/or capilary tube. The restriction of the orifice allows for a greater total pressure drop acoss the evaporator to concentrate the cooling effect in the coil where it is needed and provides a point in the system for the compressor to pump against in order to build up the required pressure that allows for the high pressure/high temperature gas to be forced across the gas/liquid phase boundary in the condensor with only ambient (normal outside temp) air being drawn across the condensor coil.
    The Phase change is the key... phase changes require vastly greater temperature changes in order for them to occur and that is the key to BOTH condensing the gas (fluid) to liquid (fluid) and evaporating the liquid back to gas to get the chilling effect inside the cabin where it is needed.
    Hope this is a clear explanation and that condensing (outside, heat dispersing unit) and evaporating (inside, cooling unit) is more clear to the group now.
    That said, the majority of the aftermarket roof unit that we have seen for the Sprinter have been RV units and are meant to run on LAND power, or a generator system. I am not aware of any (RV units) that would be run on 12v or from the Sprinter with existing Daimler/Chrysler, as the draw on the alternator would be HUGE. but with a 200 Amp Alternator, it could probably be done with a smallish unit.
    KenB
    PS... If my explanation of Condensing/Evaporating is too much, please forgive me... I was trained as a technical person with all the required thermodynamics and to continue a thread with consensation/evaporation reversed was driving me just a bit nuts and I might get carried away.
    That answers my question. The reason I asked it is that if the roof unit had contained both the condensor (with electrically powered compressor) and the evaporator, then
    1) it would possibly be feasible to install a factory rear unit on a van which wasn't built with one. But since the condensing apparatus is in the engine compartment and presumably powered by a belt driven compressor, then it seems much more difficult to retrofit a Sprinter with a factory a/c unit.
    2) there would have been the possibility of running the rear a/c off the electric hook-up via a power converter.
    For years there have been proposals to fit autos with electrically powered a/c compressors (with the compressor mounted to the body of the car (e.g. firewall in the engine compartment). This was enable the use of a hermetically sealed compressor, hard refrigerant lines, and so allow the use of more efficient refrigerants (freons)than the ones formerly required for cars due to the flexible hoses being susceptable to degradation by certain freons.
    A couple of years ago I did see a new Sprinter for sale at a dealer in Dallas which had had an aftermarket rear a/c added. This unit was on the top back, but took up more space in the interior and extended less above the roof. I don't remember the additional price, but I do remember it was shockingly high. I'd forget about trying to retrofit rear a/c to a Sprinter.
    To be concise, the factory rear air unit is like this:
    1) compressor in engine compartment (second pump)
    2) Condensor in gray box on rear roof (extra electrically driven fan to consense refrigerant)
    3) Evaporator inside in rear to cool/dehumidify/circulate the air.
    Sounds like a system to steal off of a wrecked Sprinter (sweat equity is wonderful if you can swing it)...
    KenB :shades:
    Wow! I thought the compressor and the condensor coil would have to be in the same location, like in a home unit. So the tubing from the compressor in the engine compartment carries hot compressed gaseous freon to the the condensing unit (with fan) on the outside back of the roof. At that location the gaseous freon is condensed to a liquid in the condensor coil, then the liquid goes inside the vehicle where it enters the evaporator unit with its fan which probably mostly recirculates air inside the van, but may have a setting to draw in outside air.
    This would seem to mean that retrofitting with a factory unit might not totally our of the question, but would still cost a bundle.
    What is the standard arrangement for a large minivan with rear a/c?
    A large minivan such as my GMC SAFARI (Extended, largest "mini" van made) with "rear" A/C is modified to add extra plumbing to the back and run it off of the same compressor/condensor as the front air)! Since it has a 4.3L V-6 and over 200 HP, this is OK, but you want the heavy duty package even if you don't tow a trailer (bigger radiator, stronger fan clutch, etc.)
    The interesting thing is that the A/C unit on the Safari works Much Better in the front when the rear is turned on low and allowed to circulate its share of the freon, even though the rear air, on low, gives only a little cool air.
    What I am saying is that the Front air (coming out of the vent) is MUCH cooler when the rear is allowed to circulate its Freon (even on the hottest day, right when you fire it up and try to cool down) before the rear actually contributes to the coolness of the cabin air.
    My guess is that the freon stacks up in the plumbing going to the rear and does not let any of that part of the charge circulate back to the compressor and starves the front for freon flow... but then the LONG return line from the back should always have the low-pressure (evaporated fluid/gas) in it while the compressor is running and that should be available for the pump to draw from anytime it is low?
    thanks,
    KenB :confuse:
    I doubt that a belt driven compressor could have different speeds so it could be that the compressor control system is set-up to run the compressor on a different duty cycle when the rear air is on. Or maybe the expansion valve on the front evaporator is controlled differently when the rear evaporator is on.
    The entire set-up may be overcharged with freon unless the rear unit is also on, which is another way to say what you said. The fren charge could be within specs and just works that way or it could be outside specs.
    Getting back to the Sprinter rear a/c unit, the temperature of the compressed gaseous freon is 125 deg F or so, maybe higher, before it gets to the condensor coil where it is cooled to outside ambient temperature and condensed to a liquid. I know on my car (91 dodge Spirit with R-12 freon) the line going into the condensor is too hot to grasp. The Sprinter must have that line insulated or it would be an unwanted heat source.
    the high pressure line goes to the back through stand-offs and grommets in the under-carriage/frame and can radiate heat freely (or possibly gain heat if the pavement under the van is hotter than the line itsself).
    The return line is (as Always) larger in order to pass the expanded gas back to the front and in most applications is more likely to be insulated so that it does not sweat and does not continue to gain heat from the ambient temp. (that helps the compressor run cooler and have to compress the gas less to get it back to full pressure on the hot/consensor side.
    The receiver/dryer chamber allows any liquid/two-phase fluid to return to gas before being sucked into the compressor... liquid in a gas compressor is bad...
    KenB :shades:
  • wmresourceswmresources Member Posts: 1
    Hi, I have a 06,158,cargo dodge sprinter. I have been researching information on adding rear ac to my sprinter.
    I have found some information that might be helpful to you.
    First you can go to the dealer parts department and get a copy of all the parts for their rear ac unit with part numbers. Also here are some links for real information on how the system performs. Their is alot of good information at this link about what you can expect from owners.
    http://www.sportsmobile.com/2_sr_heatingcooling.html
    The next link uses another way
    http://www.espar.com/htm/aircondition.htm
    Their is another link I called and talked to them about ac systems for comfort(they do refrigeration for sprinter only.) but are going to make a rear ac unit (like vans have now) for the 07 sprinter first, then others will follow. but I will have to find it and send it to you.
    Hope this helps
    Bill Melville
    My email is wmelvillejr@yahoo.com
  • txx1txx1 Member Posts: 3
    Another option is to install the SCS Frigette A/C unit. It has all the factory switches for the dash and it doesn't have the big hump at the top for an already tall vehicle.
    http://www.sprinter-wiki.com/wiki/index.php?title=SCS_Frigette_Installation
    The condensor unit is installed underneath the vehicle.
  • foxm30foxm30 Member Posts: 5
    Have any of you had a faint sound coming from the A/C vents that sounds like mist spraying? It only happens under acceleration and doesn't seem to be affecting anything, but I'd still like some feedback as to what it might be.
    From front vents?
    Under high humidity, I have actually had moisture spit out of the top of dash vents (above/either side of, the radio), and those vents were also wet with drops of condensed moisture.
    The van was full of noisy teenagers (as it usually is) and I did not hear any misty-moisty noises... but I could imagine there could be some since I got Spritzed at least once, leading me to touch the wet vent in the dark. After touching the problem spot, I could see the leetle round droplettes in the moonlight or streetlight.
    KenB :shades:
  • jmdeeganjmdeegan Member Posts: 3
    I have a 2004 Dodge Sprinter 2500 used in the home delivery business.
    When it is cool outside I open the vents for cool fresh air and without warning and not touching the temperature control knob the air becomes hot. It may stay warm or go back to cool. This happens with no time frame being the same. Help, I am trying to get this fixed without going to the dealer.
    This also plays havoc when the a/c is running.
    jmdeegan,
    is your temp control all the way on the cold stop?
    If not, the warm temp will come on regardless of air temp (air flow that is) if the engine is warmed up. A sensor, not sure where, will try to get the temp to a sliding-scale temp.
    Cold stop is only cooling, just off the stop appears to still give very little heat except at COLD temps (but with the engine temp up). Just beyond the cold stop, some heat is added until the sensor (wherever it is) gets up to about 62F.
    As you run the temp know up the scale, the air flow will be more and more warm, for a longer and longer time until that elusive sensor is up to the temp for that spot on the dial... It is not the (flowing) air temp that is affectively controlled by the knob as you are used to in most American cars, but rather the temp of the sensor. Until warmth gets to the sensor, the heat will remain flowing unless you have the knob on the Cold stop.
    If you are on the COLD stop and you get heat, then the control may be bad... I see them for sale on EBAY once in a while, usually the entire air control cluster.
    Write back if you have more diagnostic info after reading the listing above.
    KenB :shades:
    Thanks for the info. I will try to find out where the sensor is located and how to replace the sensor. Yes, the control knob is set on cold stop. Also will try ebay on the control panel. The panel is not cheap, I had to replace it once because the centrer knob broke. It seems like it could be the sensor because it happens when the a/c is also running.
    I took the truck to the dealer and put it on the computer. They could bypass the heat control knob on the dash control unit and the temperature would work great. I was told there is a electrical part behind the temperature control knob that went bad. Of course the small bad part can not be replaced. Replace the whole control unit in the dash and everything works great but what an expense.
  • santomansantoman Member Posts: 7
    i live in texas and was wondering will a 03 with rear air cool good enough in the hot summer??--i would like it to cool around 55 when loaded with people
    thanks dave
  • tullimantulliman Member Posts: 2
    Red Dot Air Conditioners has several units taht may work. They are not the prettiest installation, but they do work.
  • bbeckwibbeckwi Member Posts: 1
    I want to take my roof unit off and sell it and all the components for it. I'm not sure I want to mess with it, though.
  • thesparkeythesparkey Member Posts: 2
    Problem with the AC {in cab} just think it needs a recharge. I am tempted to go to the Auto parts store and get me a can of the recharge (new) freon. Anyone know the pressure I am supposed to look for as a target? the stamp under the hood says 1,90 lbs. thought from other vehics I was looking for 35 to 45 psi. Anyone played around with this before?
    this is the one that runs on diesel from the fuel tank. stopped running last winter just before 20 below weather (go figure). used to be able to press timer button in the cab and hear the heater and igniter start up and try to ignite the fuel. Now I get nothing, no sound, no click, no "little jet engine" sound. can someone point me in a direction? Does not have to be the correct direction:)
  • cgarland2cgarland2 Member Posts: 2
    Ken,
    thank you for all the insight on this system. I have an alldata account, but I still can't find the high and low side test port for the rear compressor. would you please let me know where to look for them? I would like to test prior to sending it in for service.
    thank you in advance,
    cg
    I found them behind the filter in the rear of the van.
    thx,
    cg
  • kosar1kosar1 Member Posts: 1
    edited August 2011
    my mechanic for sprinter has put hundreds of airconditioner in however the clutch plate on my dodge sprinter has broke 4 times so far after driving 500 miles or more.does it when its idleing.
