Ford Mustang Wheels and Tires
I am finally putting a new set of wheels on my mustang gt. I have chosen to put 18" Diablo wheels on it, but want to increase the tire size from a P245 to a P265. Will their be enough room?
filo
Of course, having Ford recommend a lower psi than the Max shown on the tire reminds me of the Explorer fiasco. Hope there are no issues here.
:confuse:
The owner's manual tells you where to find the sticker.
DO you really think that dealers have somebody go around and back pressure out of all the tires on the lot? Who do you think they would be able to bill for that?
ALL cars are shipped with the tires at higher pressure then recommended for regular driveing to prevent flat spots durng shipping.
At the dealer, the service department preforms a Pre Delivery Inspection. I suppose at that time the tires could then be under inflated but that would mean you have service personal doing something they know is wrong on purpose and therefore assuming the liability.
Mark
i heard that if you drive long on tires it will tear-up your transmission
Almost everyone drives their mustang on tires. Driving it on the rims is definitely not a good thing.
Running 20" wheels will indeed cause more stress/wear on your brake pads. Mostly because you're adding more weight/rotational mass to your car with those big boys, and also because as your stopping distance is increasing, you'll be on the brakes more often.
You might want to look into some heavy-duty brake pads that resist wear/fade.
As for how they ride, the answer is bad, and your performance will drop. Also, you're going to be shelling out huge amounts of money for new tires. But if you're comfortable with that and you like the look, then enjoy!
any suggestions?
You might have to fudge a little on the exact size but as long as you're within 5% of the OEM tire diameter it's ok. Maybe even 10%.
My question is: What will it do to the computer if I don't use the low pressure sensors and rings?
Any input on this subject will be very appreciated.
Mark.
If I had known about this problem I would have kept the 06 but it had an electrical problem, the Shaker 1000 kept draining the battery when it was parked. The dealer still hasn't been able to fix it. But it's their problem now.
Everone else puts the sensors on the inside of the valve.
Ford realized that their first idea was stupid from a cost standpoint as well as sensors were getting ruined by people who didn't know what they were or that they were there. I think it was the strap more than the sensor getting ruined but I digress.
Accordingly Ford is in the process of abandoning the straps and going with valve mounted sensors.
THAT is why the sensors on your 06 are not compatible with your 07.
Mark
Mark
When I went to start my 06 Mustang with a dead battery for the 4th time, I took my 10 amp battery charger and attached it to the battery and the radio came on for about 10 seconds then shut down. After having it towed to the dealership again they kept it all the next day and all they could do was charge the battery. I picked it up and drove it straight home, pulled into the garage and turned off the radio then the ignition. It sat for 3 days and when I returned home and opened the door and the door glass did not drop and the map lights did not go on, dead battery.
Hence, the 07. To my knowledge, they still can't find anything wrong with it so they are going to put it on the lot and sell it.
When the weather warms up a little I'll go out and take a look at those sensors and try to make up my mind on what to do.
I could be wrong but I don't think the 06 had any sensors on it as I used to change the wheels back and forth and never seen any signs of warnings or such.
Thank you Mark for all the info, I really appreciate it. I hope I will be able to help you someday.
I purchased Saleen wheels 18X9 for the front and 18X10 for the rear.
I also want to lower about 1.8"
What size tires do I need and will I have to do any other modifications?
Any potential problems with this set up??
I had some more road noise with these so I turned up the radio.
Don't know if that combo will clear a 2000 Mustang especially if you drop it 1.8".
Allot will depend on the back space of your wheels. Good luck.
You can get some nice looking tires on that 10" rim. I have 10.5 and run 315's on mine, but I have 17" rims. The biggest things that you will notice is that the ride and performance of the car will suffer. The added weight of the bigger wheels and tires is going to act like a ancher. Sure, it will look cool, but don't plan on racing anyone and your brakes will wear faster too.
Also, the sidewalls will be a lot stiffer which will hinder traction a lot. You will want to drop the pressure on the tires to about 25 lbs just so you don't feel like you are driving on ice.
I am not impacted by the added weight so much as I have 4.10's on the back and 400 rwhp.
Make it the way you want it.
I put a set of snow tires on the stock rims that came with the car, and I want to get a summer set of wheel/tires.
Can I but another set of TPMS sensors online and install them in my summer set of wheels, or will my car only recognize the set that came with the vechicle?
Thank You.
My biggest question is: Can I run wheels that don't have any sensors at all and what will it do to the computer?
Maybe Mark @ mschmal can shed a little light on this subject.
Can I purchase another set of TPMS sensors and install these on my summer set of wheel and will they work with my car or is the set that car with the car married to it?
I called over to thetirerack.com.
I was told the you can buy another set of sensors and mount these on another set of wheels.
The sensors (I was quoted $80 per wheel for sensors & bands installed) are all the same and are not married to the car.
Hope this helps anyone looking to answer the same question. :confuse:
