PLEASE HELP -_- Altima problems
prodbynysomprodbynysom Member Posts: 1
edited July 2019 in Nissan
Okay! So I have an 05 altima 3.5l with 130k miles That was driving BEAUTIFULLY until one day I hit a bump hard in the city then the car stalled. Took it to autozone and code p0340 came up. Replaced the bank 1 and bank 2 cam sensors with cheap chinese sensors (I know) and then had the same problem. Took it to a [non-permissible content removed] mechanic, first tried to tell me the tranny was shot then advised I replace sensors with OEM NISSAN. I bought new genuine oem nissan sensors (bank 1 bank 2 and crankshaft) and had them all installed.. Now mechanic said there was a code for transmission speed sensor. Bought an oem Transmission Speed sensor, had him replace it and said he now thinks transmission is shot because car has little acceleration in drive and clunks in reverse.
This problem happened while I had the p0340 code and would sometimes go away after resetting the negative terminal, then reappear, which leads me to believe the transmission is not bad after all. Im pretty sure the car not accelerating with enough power or going over 2k RPMs is attributed to it being in limp mode, but what the hell do I know?
Any advice?
