Why wont shift in reverse and my netural light blinks.
I was driving doen the highway when i hear a clunk and my netural light started blinking and it down shifted. I stopped and now it wont go in reverse.
Answers
Could be one of the transmission’s sensors or solenoids failing, or it is possible that a mechanical fault has occurred. If the transmission is downshifting, then it may be possible that the issue is serious enough that it is putting the vehicle into limp mode, which is a power reduced mode that is activated in order to protect the transmission from suffering possible damage.
Since it appears to be in limp mode, you should stop driving the vehicle and have the transmission trouble codes retrieved by a qualified mechanic to see what's going on.
