2002 Sebring Convertible limited engine stalls
depalmatdepalmat Member Posts: 1
edited October 2019 in Chrysler
When engine is cold, car will stall and can be started in neutral or it will restart itself while moving. Engine light comes on and the car runs great.Engine codes do not reveal cause and service cannot find the problem unless they experience it themselves. Car has 140k.
Anyone experience this condition?
  • RicardowelchRicardowelch Member Posts: 15
    depalmat said:
    When engine is cold, car will stall and can be started in neutral or it will restart itself while moving. Visting Autoguysland to know why check engine light on but no codes if you concern. Engine light comes on and the car runs great.Engine codes do not reveal cause and service cannot find the problem unless they experience it themselves. Car has 140k.
    It could be fuel mixture that isn't rich enough. Take a lose look at this.
  • thecardoc3thecardoc3 Member Posts: 5,878
    What codes are setting? Trouble codes don't tell you what part is bad, they tell you what test failed.
