My 2007 Toyota Tacoma's headlights won't switch to dim they are stuck on bright any ideas
WarEagle1WarEagle1 Member Posts: 1
edited November 2019 in Toyota
Answers
    The simple solution would be that the combo switch has gone bad. Might also be some kind of relay or controller issue
  • thecardoc3thecardoc3 Member Posts: 5,862
    The dimmer switch is an input to the body computer, the body computer commands the operation of the DIM (dimmer) relay in the underhood fuse block based on that input. Does the "flash to pass" function work ?
