Transmission no shift after 28
Bobbysauto248Bobbysauto248 Member Posts: 1
edited November 2019 in Nissan
my trans has the first 2 shifts no problem/no slipping /no hard shift plenty of power but stopped shifting into hi gear---red fluid-no metal in pan/
Answers
    What year and model? Regular automatic I assume? Could be a shift solenoid issue
  • RicardowelchRicardowelch Member Posts: 15
    my trans has the first 2 shifts no problem/no slipping /no hard shift plenty of power but stopped shifting into hi gear---red fluid-no metal in pan. Visit AutoGuysLand to review why manual transmission wont go into gear if you concern./
    It could rule out low fluid level or a plugged transmission fluid filter. It is also internal hydraulic leaks in the valve body or failing internal transmission seals found on clutch pack pistons and piston o-rings.
