noise going around right hand curve
lazy466lazy466 Member Posts: 1
edited February 2020 in Isuzu
when i go around a curve to the right i hear something like a rubbing or low grind. i can feel a small wobble in the steering wheel during this time. i have lifted the car and checked for wobble in the tire. the bearing seems tight. no slack. the upper wheel bearing boot is busted but dont know if it is loose. i haven't taken it apart yet to check. i also have recently put front breaks on the front and didn't open the bleeder valve when bleeding i was told this could damage the abs. would this make that noise?
