Speedometer stops working, ABS lights on Check Brakes light on Transmission in 1st and 2nd gear only
Jimbob58Jimbob58 Member Posts: 1
edited August 2020 in Chevrolet
Speedometer goes to Zero, ABS lights on , Transmission only in 1 or 2 gears Intermitted problem 10 Times in last month.
Replaced all 3 speed sensors, had new front brakes and ABS sensor replaced on front, Cleaned all cables and main fuse 125 amp.
