Throttle position sensor: detachment and spraying with cleaner
Laith1986Laith1986 Member Posts: 1
edited October 2020 in General
1. Does the TPS get damaged if it is detached from the throttle body before cleaning? I told my mechanic to detach it to avoid contact with liquids but he said it will get damaged.
2. will spraying throttle body cleaner into the opening of the TPS, where the pins are, do any damage to the TPS? The mechanic said it is OK and did spray.
Did he do the right thing? Thank you
