Any idea what PN this ABS wheel sensor is?
JimJerseyJimJersey Member Posts: 1
edited February 2021 in Ford
Trying to get this to post in "Maintenance/Brakes" I tried changing this bad ABS sensor (front right) on my 2003 ford expedition. All searches and parts stores show a sensor almost 1/4 longer than my removed sensor. They sold me a "ABS638" from A.A. Sensor I removed is 0.71" long. Cable is approx. 48", tip diameter is 0.375" (3/8") and diameter of 0-ring/hole is 0.400". Inserting it hits into the reluctor tone-ring, and also looks different with a flat tip. The hub must have been changed from stock. Can anyone tell me what part number abs sensor this is? Or how to search sensors by dimensions? I'm seeing some Duralast sensors that look similar but different connectors. Also, there seems to be a "1126" or 1i26, 1l26 stamped into the sensor plastic.
