Wont crank fuses, starter or electrical problem????
ya_uplanders_suck_1ya_uplanders_suck_1 Member Posts: 2
edited January 2024 in Ford
ONE DAY DRIVING I HEAR A CLICKING NOISE UNDER THE STEERING WHEEL AND ALONG WITH THE CLICKING DIFFERENT ELECTRICAL THINGS WOULD COME ON THEN TURN OF EXAMPLE: I HEAD THE CLICKING NOISE AGAIN AND LOOKED AT THE INSTRUMENTS NOTICED THAT THE 4X4 WAS TURNING ON THEN OFFF... ON THEN OFF.... ALONG WITH THE INTERIOR LIGHTS?????? THE CLICKING NOISE I FIGURED WOULD BE THE IGNITION SWITCH SO GO ONE OF THEM PUT IT IN THE TRUCK NOW THE THING WONT CRANK???????????? POWER IT THE I HAVE 2 BATTERIES POWER IS THE EVERYTHING LIGHTS UP BUT WONT CRANK I HEAR A LIGHT THUMP IN THE FIRE WALL THATS THE RELAY I THING WORKING PROPERLY OR EGR OR WHAT EVER , IS IT A STARTER OR A PROBLEM WITH MY FUSES UNDER THE HOOD??? LOVE THIS TRUCK TRITON IS ALL RIGHT NOT A BIG FORD FAN BUT THIS TRUCK I LIKE 2V 5,4..... ONE OF THE FEW TRUCKS I CAN ACTUALLY WORK ON ANYWAYS SOME HELP
  • BrownKuhicBrownKuhic Member Posts: 1
    The truck not cranking after changing the ignition switch, there are a few possible reasons, such as:
    You did not reset the password for the security system, which can prevent the engine from starting. You may need to perform a relearn procedure to sync the new ignition switch with the security system.
    You did not connect the wires properly, which can cause a short circuit or a bad ground. You may need to check the wiring diagram and make sure the wires are connected to the right terminals and are not loose or damaged.
    You have a bad starter, which can make a thumping or clicking sound when you turn the key. You may need to test the starter for power and resistance, and replace it if it is faulty.
    You have a blown fuse or a bad relay, which can interrupt the power supply to the starter or the ignition switch. You may need to check the fuse box and the relay box under the hood and replace any blown fuses or bad relays.
