grease while replacing tie rod boots?
paulmarspaulmars Member Posts: 9
edited March 2021 in Toyota
When I replace the boots, I usually add some ball joint chassis grease to the inner ball joint. Should I also
turn the steering wheel completely right and add grease to as many of the rack splines/teeth that i can reach?
note these pics are not mine, just pics I found on internet to illustrate:
https://www.customtacos.com/threads/grease-while-replacing-tie-rod-boots.197354/
  • rickdonrickdon Member Posts: 123
    You will be fine. Just use high-quality grease.
