Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
OR
A-TRAC and VSC on 2001 4WD Sequoia Limited
I've searched the whole internet, talked to Toyota, and never got a complete answer to the following:
On the 2001 4WD Sequoia......
in 4WD H or L
When you press the VSC OFF button, does A-TRAC also get disabled? H or L or L only or not at all?
Or, do you have to disconnect the brake fluid sensor on the master cylinder to turn off the A-TRAC?
If you need to disconnect thew connector, installing a switch makes sense so which wire do you splice in to?
Lastly, ever thing as factory, when you press VSC (in 4WD) is the throttle controlled or do you have full power?
Thanks in advance for any insight!
in 4WD H or L
