How to adjust GMC Yukon Denali Headlights?
I know how to adjust the vertical (up and down) adjusters
I need help finding how to adjust the horizontal (side to side) adjusters
Please let me know
Please let me know
1. make sure all your tires are properly inflated...
2. park on a level surface with no extra load in the back of your Yukon
3. your vehicle should be 90 degrees to the wall that you are using to adjust your headlamps aim (If your Yukon is equipped with auto leveling system, you probably want to keep the engine running to maintain the ride height; ...come to think of it, keep the engine running anyway to avoid running down the battery...)
4. the distance between the plastic face/lens of each headlamps (there is a tinny circle marking or called "aim dot" on each side of the lens) should be 25ft away from the vertical wall (the right way to measure the 25ft is first mark the floor where its vertically down from each headlamp's aim dot, then from each mark measure 25ft straight out to the wall)
5. You may want to draw a horizontal reference line across the wall at the same height as your vehicle's headlamp's aim dot, then two vertical reference lines at the same distance between your headlamps (left-aim dot to right-aim dot)
6. Turn on the low beam for the aim adjustment, basically looking at the wall to verify that the top of the light cut-off projected on the wall is with +/- 2 inches of the horizontal reference line (you may want to block the light projection from the other headlamp to only see the one you are working on - **** NOTE: DO NOT PUT a towel directly over the headlamp as that will cause over heating and damage to the headlamp unit ******)
BTW, to adjust the headlamp vertical aim, raise the hood, on top of each headlamp unit you should see a male star screw in silver color (some call it torx screw); Adjust the screw left/right for each headlamp as needed for proper aim height. Good Luck!!
Oh, aftermarket bulbs... I think 08 Yukon also uses the H13 (9008) bulbs; standard brightness of these bulbs are around 3100K. I am sure there are many brands out there (Hella, Luminics, NOKYA...), my personal choice is the one from PIAA (Xtrem e White Plus @ 4000K, otherwise the less expensive from Sylvania (Silver Star @ 4000K, Ultra if they have the H13 Bulbs @ 4100K). Per my experience, the PIAA bulbs although are more costly, they seem to last much longer, especially if your Yukon has the DRL. By the way, some states have strict laws around how bright & color one can use on their vehicles, that is why I only mentioned the 4000K as they are brighter than standard halogen and still legal. Hope this helps...
